Newbie Question-24P and 24Pa
Hello,
I'm a new member to the forum and I have had my XL2 for about a year and a half now. Unfortuantely, I'm stuck editing on iMovie, but I'm in High School, so I guess that's normal at least for the time being. I jsut had a question about 24p and 24Pa. What is the difference? If anyone can just give me a quick overview of both that would be great. I've read some past posts, but I am lost in the editing world with anything beyond freeware. Thanks again, Marc |
Transferring your project to 35mm motion picture film? Use 24Pa (known as 2:3:3:2 in the XL2).
Not transferring your project to 35mm motion picture film? Use 24P (known as 2:3 in the XL2). That's the gist of it and pretty much all you need to know in very simplistic terms. |
Thanks Chris :) -Eric |
And is there a visible difference between 24P and 24Pa? Are there fewer interlaced frames with Pa? |
http://www.adamwilt.com/24p/index.html#24pRecording |
"Shoot 24p Standard for: * Getting the “film look” on video when you're staying on video and editing at 29.97. * Intercutting with film transfers also using 3:2 pulldown, and staying on video at 29.97." I realize that 24P is stored at 29.97, but isn't there redundant info in there? Isn't capturing to 23.976 better because it uses less space and has all the same info? It seems every time I read about this stuff, I find contradicting info. :) Thanks! Eric |
But then this one says do 30, so which way is right? |
Here's another article link from Digital Content Producer - "Shooting for DVD"
http://digitalcontentproducer.com/vi...DVD/index.html |
Who says "do 30"? You did not provide the reference... Anyway, if you are writing to tape first, it is 24fps, but within 60i stream. This way you can watch video directly from the camera on a consumer equipment, even on a old-style analog CRT TV. Also, you can edit video as if it is regular 60i. I don't think that you can shoot true 24p with regular DV or HDV. After all these standards were envisioned as consumer standards. So the only way to get 24p from these systems is to store it in 60i stream. Once you are mastering a DVD you can create a true 24p DVD by reverse telecining if you want. Obviously, your software has to support that. |
Thanks for the link Jack, I'll check it out.
Mike, direct to dvd, as in not going to theaters first. I have an XL2 after all, so it's standard DV codec all the way for me. :) I can't find anything at the moment about capturing to 24fps vs 30fps timelines. But I've seen posts about resources and cpu efficiency capturing at 24fps. I use Premiere Pro or Vegas, depending on the project. |
I was doing some test shooting for a upcoming PSA I need to work on. Was seeng what the differance was between 24pn & 24pa in post with FCP5. There is one shot that we will be needing to make it look like it was shot with a fisheye adaptor (we won't have one). And the thing I notice is that after doing that to the shot on the timeline, with 24pn, there is very noticeable aliasing going on, with 24pa, it is very slight. So we were going to choose shooting in 24pa. The final project will be going directly to DVD. Doesn't it output to DVD as 29.97? Or would there be any problems with the frames playing?
I've noticed vertical bands in my footage sometimes. Almost like every 100 pixels or so, there's a stretch of 10 pixels. It seems more apparent on strong blue images. I'm shooting with a Soft/FX 3 filter, but that has an obvious pattern that looks nothing like this. It's almost like it's shooting narrower than 720px and stretching at a standard interval. Anyone else getting this? Eric |
