Xl2 B&w
I have been experimenting with new styles of lighting and a different editing pace. A couple of weeks ago I was taking head shots of Jesus Fuerte, I mentioned to him my side projects and he jumped onboard this piece. I got BBP's in-house editor, Robert Brazius to donate his valuable time. I would like to share with you some of the specs.
Acquisition Cameras Canon XL2 with EF-XL adapters Lens EF 50mm and EF 24-200mm F stop F4 Camera Setting 24p 1/48 Gama Cine Knee set to middle Black middle Set up level -1 everything else set to factory Audio Sennheiser ME-66 shotgun mic on A camera on board mic on B camera Lighting Photoflex 1k Octdome Arri 1k fresnel w/diffusion Arri 650 fresnel w/diffusion White bounce Post FCP NTSC timeline De-saturated, de-interlaced image Levels Corrected for web and broadcast Lowered contrast -4 web Exported Self contained uncompressed 10 bit 4.2.2 quicktime a 4.5 GB file Compressing video for the web is like sending water from a firehose to a straw. The crisp details, shadow gradations and perfect highlight blooms all there in the broadcast monitor; then you look at the web compressed version and it just makes you want cry. Well, though my tears and working with a technical director, I have modified my lighting over time and I have a better understanding of how the end medium we look. A rough guide to follow the duration time was from a web commercial job. The maximum throughput is the end users modem speed and the file size is figured so that the movie will download and play fast and smooth. Duration Maximum Throughput File size must be below 178sec 56K 973 112K 1946 256K 4450 384K 6675 512K 8900 768K 13350 Compressor Type H.264 Quicktime 7 Frame rate 15fps Key Frame 75 frames Data rate automatic Pixel aspect ratio: NTSC CCIR 601/DV (16:9) Hinted streaming Audio Encoder AAC, Stereo (L R), 32.000 kHz Dimensions 480x279 End size 3.9MB Quicktime movie The finial product Jesus Fuerte http://www.bluebarnpictures.com/blog/ Cheers David H Castillo Director of Photography Blue Barn Pictures, INC |
