Anton Bauer adapter won't stretch...any ideas?
I'm trying to attach the Anton Bauer QR-XL1C to attach to my XL2. I have the Canon supplied rear plate screwed in to the camera, and now the AB adapter is screwed to that via the small area with the 3 screws at the bottom. Seems okay, only trouble is the adapter that plugs into the camera's battery-in socket won't reach - the cord is just too short. Am I missing something? Any thoughts or ideas would be great.
thanks, Oliver |
I think I've just figured out the solution/problem. The actual AB gold mount which was attached to the AB metal plate via the 'upper' set of 4 holes. There is a slightly lower 'lower' set of 4 holes. I took off the mount and reattached using the 'lower' holes and the cord just barely stretches. It is very tight and I just pray that on a shoot the cord doesn't yank out of the battery connector. This could work better this setup.
Oliver |
Check a little further down the XL-2 forum.
http://www.dvinfo.net/conf/showthrea...threadid=35886 This poster got a solution from Anton Bauer. =gb= |
