-   Canon XL and GL Series DV Camcorders (https://www.dvinfo.net/forum/canon-xl-gl-series-dv-camcorders/)
-   -   Changing Tape Brands (https://www.dvinfo.net/forum/canon-xl-gl-series-dv-camcorders/43885-changing-tape-brands.html)
Derek Hoffman May 1st, 2005 09:04 PM
Common knowledge is that there is a thin film of lubricant on the surface of miniDV tapes and each manufacturer uses a different type of lubricant. I heard that switching tape brands (using sony for one shoot then switching to panasonic for the next) can cause the lubricants, that unavoidably build up on the recorder head, to mix and screw up your recorder head. Obviously you can use a cleaning tape to clean it but do you know if this "lubricant build-up" story is true or false, even if you dont know... what are your opinions?
Rob Lohman May 2nd, 2005 03:52 AM
This is true. It can glob up your heads (they should not really be damaged
by this or anything) and this can destroy recordings or pose troubles with
reading tapes. It is always good to use a head cleanin tape before switching
tape types/brands. Try to keep this to a minimum! If you often need to
capture different tapes a seperate camera or DV deck might be an option.
Anthony Marotti May 2nd, 2005 06:08 AM
What Brand do most of you use?
Chris Hurd May 2nd, 2005 07:28 AM
Choice of brand does not matter so much as not switching brands.
I use Panasonic PQ and MQ series but a lot of my friends use Sony Premiums.
Derek Hoffman May 3rd, 2005 04:28 PM
Tapes
I use panasonic. I know they are all basically the same but i trust Panasonic and TDK the most.
Greg Boston May 3rd, 2005 10:20 PM
I have been using the TDK tapes in all 3 of my Canons without a single incidence of tape drop out. Like Chris says, pick a brand and try to stay with it.
-gb-
