The Saga Continues
Hello once again!
I recently finished shooting a small scale short film with the XL2 and had a complete blast. The lenses used performed amazingly and I can't wait to use it again! While changing the lenses though (prepping the camera for storage), I noticed what seemed to be a speck on the CCD. I cannot determine if this is part of the CCD sensor or not. There has not been ANY change to the image quality that the camera produces (fed it to a 25" TV as well to check), so I'm inclined to adopt a "don't fix it if it ain't broke" mindset...but if something is wrong with the camera I'd like to get it rectified. Anyway, should I just let a sleeping dog lie (if it's anything to begin with)? Thanks for all your help! This place has been invaluable since I began researching the XL2. |
When you changed lenses, most likely you did not see a speck on the CCD. What you saw was probably a speck on the CCD block prism face. On the camera body, when you take the dust cap off and look inside the lens mount, you can see what looks like a CCD in there, but actually you're really looking through a prism at the three CCDs superimposed on each other. The surface of the prism block sort of protects all that stuff inside. Each CCD is hard-mounted on the prism; there's no way for dust to get in there. You do need to keep the outer prism face clean though, and free of fingerprints, dust and so on.
I'd visually inspect it closely every so often and clean it if needed. Try not to touch it of course, but if you do, it's no big deal.
This has me confused still haha. I cannot tell if it is a speck of dust or something else. It is only visible when a little bit of light bounces off of it. I'd be more concerned if there were any imaging issues, but I'd be darned if there were any... |
Just clean it like you would a lens; at least that's what I do.
Alex,
Keep a small can of compressed air made just for this sort of thing handy. As opposed to mechanical cleaning by touching the prism face with a cloth. As to why you aren't seeing this 'speck' in your image, that's because it's so close to the ccd block that it is completely out of focus. In fact, we had an engineer at the semiconductor company I used to work for who came up with a way to keep dust specks far enough away from the reticle(the actual circuit pattern on a glass plate) so that they were completely out of focus and would not transfer to the face of the silicon wafer. His solution was an additional glass plate called a pellicle where any dust particles would land which sat at a distance so as not to focus on the wafer. It was a tremendous boost to device yield per wafer. In short, use compressed air first, then mechanical cleaning if necessary. -gb- |
