Big problem with lens warning in XL2
I own a Canon XL2 and it suddenly started displaying the message "Check the lens". I changed the lens, and started to work fine again. But half an hour later it started with the same message "Check the lens" and suddenly the image in the viewfinder is black and appears in red letters "Lens". I cannot record a thing.
Please Help !!! |
Now remove the lens and I like to point the camera down to keep dust from getting in there. Inspect the mounting ring on both the lens and the camera, make sure there is nothing foreign covering the lens mount, you can also clean this area with a soft DRY cloth. Finally re-install the lens as directed in the manual RED dot to RED dot and turn to CLICK. Get the backup battery back in the unit, the main battery on the cam and see if this fixes it. If NOT you might have a unit that has to go back to Canon. This message is noted in the manual on page 107. Miguel |
Problem resolved
Miguel:
Thank you really really much for your help. I did everything you said and the camera works great now! You have saved my life, with all the work I have to do ! Thank you again. Regards Manuel Ps. I also have a wonderful wife to! |
