Using a polarizer with the XL2
I have a couple of quick questions about using a polarizer with the XL2. It seems to me that it make be awkward to use a polarizer on the XL2 because of the lens hood. Have any of you any tips on using the polarizer? Do you work without the hood when using it? How do you get around the problem of turning it if it is behind the lens hood. I have seen people say they use a linear polarizer with the XL2, is this used on manual focus only? Or is the XL2's focusing system different to 35mm systems that need a circular polarizer in order to auto focus?
Colin |
auto focus would still require a circular polarizer. I use a polarizer on my XL1s, identical hood setup to the XL2. I reach inside the hood to set my polarization and then leave it while I shoot. If necessary, it's nothing to take off the hood for a shot...although you'll want a flag above the lens of some sort. I attribute alot of the color richness I'm getting with my XL1s to my polarizer, I don't shoot without it, indoors or out.
Colin |
I went with cheap, but brand name ;) Works like a champ...someone will come along to argue with me soon, but I'm shooting DV and quite frankly, I don't believe is has the resolution to pick up the differences between the $25 one and the $50 one that I looked at. If I were shooting 35mm or even HD, the differences may be more evident and I might be a tad more concerned.
Locally I shop at Ritz and Central Camera for all my accessories. |
I ALMOST always use a circular polarizer with my XL2. The bezel is nice and loose (unlike some) so I can spin it with a single finger while the hood is on. I also think that the color richness of many of my shots is because of (correct) usage of a polarizer.
Remember that just because it's screwed on, doesn't meanit's working. It has to be set. DJ |
Colin |
The polarizer will help get rid of "haze" from off axis light hitting the pixel next to the one that should be getting hit for a given piece of colored light. It enriches the color and allows you to get specifically the light information you want into the camera.
While this explanation may be technically wrong in some small aspect, they are my observations and work well for me. With the polarizer off, I get washed out colors even when exposed correctly, even under controlled lighting. |
I find that it enhances the film look only in so much as professionally videography and cinematography cut that haze out. Richer colors are not indicative of film, necessarily, but haze IS indicative of amateur videography. So you're not making it look more like film as much as you're making it look less like amateur video.
As far as settings, I love the fact that the XL2 has them, but I don't use them. I like to get a well balanced, rich image in-cam and do anything and everything else in post. Correction: The only setting I do use that helps the polarizer is to leave Gain at -3. It helps with grain and to drop out the blacks. DJ |
I am actually working with a friend to try and recreate the look of a polarizer on an image in a Photoshop plug-in. We currently have a plug-in that will create photographic effects in one-click. Using the XL2 will also help me recreate other effects, as I can use the settings such as "knee" "color matrix" etc to be a base for other effects. Colin |
Colin |
polarizer is good, but you loose about 1 to 2 stops.
coated polarizer are better since they transmit more light, but the price can go very high. The best are Hoya , the pro1 serie, ultra-thin (glass is 1 mm instead regular 3mm) and the frame is only 5mm thick (usually between 7 to 10mm). And it get the thread on the front , so you can add another filter on top of it. turning the glass when insid the lens hood can be tricky, but usually the glass position, once found, does not change. |
i cannot help for the XL2 since i own a FX1.
I found a chinese guy who sell the hoya pro1 for cheap (usual price goes up to 200$ since the FX1 require 72mm diameter filters) http://cgi.ebay.com/ws/eBayISAPI.dll...tem=7605705533 (not received yet) For sure, you can get a regular CP (circular polarizer) for as cheap as 10$, so you want perhaps give a try with this kind of cheap stuff to make your mind. |
The thin version of the Hoya (and others such as Tiffin, Lee and B/W etc) are not any different to the normal versions when considering quality of the actual filter itself. The main reason for using the thin and more expensive 'pro-thin' versions are when they are used on a wide SLR lens to prevent vignetting at the corners (that is sometimes caused by a thick filter housing ring).
I use the thin versions on some of my ultra-wide lenses bayoneted to SLR & DSLR bodies, but not for camcorders such as the XL2, as I have found no vignetting with thick ringed converters used on the 16X, 20X or 20X + wide angle converters. The B/W are probably one of the very best brands for high quality glass filters, and I use them a lot, but I also have a selection of screw-on Hoya and Tiffin filters (and Cokin Grad filters with bellows) that are used for my SLRs and XL2 cameras. A polarizer does not only cut through haze and deepen/enrich colours, but more importantly it cuts down glare for glass, metal objects, wet objects etc. The polarizer also acts like an extra ND filter - which is handy for bright light conditions; although I tend to remove it during dawn and dusk periods to gain back extra stops of light lost via the filter. It will also cut through surface glare of water and these facts make it the most important filter that I own and is on the end of the 16X or 20X lenses most of the time. There are non-coated, coated, and multi-coated versions of the polariser, and the coated version is OK most of the time, but the multi-coated version offers a slight advantage if you are not using a hood, bellows or matte box. There are two main versions of the polarizer filter : Linear and Circular. The Linear was the first version to be made, but when cameras such as the Pentax LX Pro manual SLR camera was first produced (1980) - that had a metering system that split the light path - and later versions of autofocus cameras that also split the ligh path before making a metering reading - a new version called the circular polarizer was made to prevent inconsistant meter readings caused by using a normal linear polarizer filter. I only buy Circular polarizer filters for all lenses used on my cameras - SLR film, digital, and DV camcorders. |
I was thinking the thin versions of the filters would be better optically also, less glass, less distortion. Out of interest have you tried stacking two polarizers? It may just be the ones I have for my 35mm gear , but if I stack two and rotate them to different angles I can get the same effect as a blue/yellow polarizer ie. boost blues or yellows depending on rotation. Also if my memory serves me right I read once that using two on video/film cams can act as a fade in/out filter when rotated during shooting. Colin |
