Optical Stabilzer Question
Just got my new XL-2 yesterday. I noticed that there is a slight stuttering of the picture every so often that only occurs when the stabilizer is engaged.
I observe the stuttering in the EVF.......it is more pronounced on my LCD Editing Monitor than on my JVC Hi-Resolution (not HD) record studio monitor. Is this related to the Optical Stabilizer when fully zoomed-in to a subject and there is movement by then camera operator? Thanks in advance, LOU |
Hi Lou,
Is the camera mounted on a tripod when this is happening? If so, then the explanation is that the OIS is fighting the intentional movement of the pan (or zoom). In this case you want to turn off OIS. |
Lou,
I'm pretty sure Chris hit the nail on the head there -- turn the OIS off when tilting or panning. Your situation is exactly what happened in a shoot I had done earlier today. Unfortunately, one instance of some B roll footage I took is useless because I had my XL2 zoomed in quite a ways, and when panning the camera, I noticed lots of stuttering in the footage once I captured it. It then occurred to me that I got lost in the moment I was shooting and forgot to turn of the image stabilizer. Turning it off should correct your issue. |
I am handheld. ???
Exactly what I observed.......going handheld.
what frame rate are you using?
60i.................
Lou, I've known you online for a very long time... going back to usenet days... so in your case I think the problem might be that all of your experience in handholding cameras has perhaps caused you to become too good for the OIS. Your technique might be so steady that you're unintentionally fooling the OIS into working against you. Try switching it off and see if the situation improves.
Thanks.................I did just that. It seemed that my shot was very steady.
Any slight flinching caused the "scene" to catch-up with the slight movement. SO.................for long extended shots, the OS is OFF. Thanks again!! LOU |
