Zooming when moving...
When I move when zooming in it seems to stop the zooming til I stop moving and then it'll work fine... Anyone know why?
Is Image Stabilizer turned on while you are doing this? If so, try turning it off.
Mike |
Would this also be a problem in manual mode, using the zoom with the motor, while focusing by hand, since the focus is servo controlled?
What is the point of the full manual lens, btw? I've used studio and handheld high-end cameras, but never needed to look at the numbers, but the numbers seem to be a big selling point? :) i could see having a quicker response than the servos provide. But what's the big deal? :) -Eric |
Yes, you cannot manually adjust the focus whilst zooming in using the servo. It's a bit annoying, but like somebody else has said, you need to make a choice on which is more important
You know guys, the OP never even mentioned focusing in his question. He's having trouble zooming while he's moving.
we're having trouble focusing on the question ;)
So then is the problem that the motor isn't running/moving the lens while being shaken from movement? sounds like a wiring or mechanical connection problem to me. |
Unless he is moving in a circle around his subject and is maintaining exact distance and aiming at the same spot, then the distance to the subject will change and the camera will attempt to focus. The camera's auto focus does not care whether you move 1 foot or 10 feet away or closer, it will try to maintain perfect focus, and this is irregardless of your depth of field. To foil this auto system you might try this: Close down the iris as much as possible and increase shutter speed to maintain the look you want. This will give you a great deal of depth-of-field, then turn auto-focus off. That might work. Otherwise, the motor simply can't do both at the same time. This is also true if you turn off auto-focus and use the focus ring, or zoom by hand, because the zoom and focus rings are not really manual as you are only actuating the motor by turning them by hand. A Canon 16x manual lens would work if you are good at maintaining focus, as the focus ring is true manual and the zoom can be operated by servo or manually. Good Luck----Mike |
Mike, the OP not only didn't mention focus, he didn't mention auto focus. What the heck are you talking about?
Mike |
I know the original poster said nothing about focusing. But given the operational restriction of the lens, and the description of the problem, it is a fairly safe assumption that auto-focus was on at the time. -gb- |
