Looking at buying an XL2..accessory advice?
Hi Everyone,
I'm looking at getting an XL2 and some other gear and I was wondering if I could get some advice on the gear I've priced out on whether it is a sound item to get. So here is the list so far: -Canon XL2 Kit (Camera and Lens) -Porta-Brace CTC-3 Traveler Camcorder Case -Porta-Brace RS-XL2 M/DVRain Slicker Blue -Canon FS-72U Filter Set -Sennheiser ME66-K6 Kit & Windscreen* -Digiflex 10' Mic Cable XLRf to XLRm *(I'm waiting for feedback on the sound board for a shotgun Microphone currently). I have a limited budget, and I had to include the video editing software (yay my own copy of Adobe Production Suite!) and a PC I'm going to build (Quad-core core2duo). I'm ordering all of the camera gear from Vistek.ca since I then won't have to worry about paying duties. Thanks! |
if you can swing a senn 416 shotgun, go for that one. forget the filter set. You will want 4x4 matte box and filters later on- good for grads- however you should get a 72 UV to protect the front element from damage. good luck
Hi Craig,
After discussing my mic situation with Ty Ford, I'm dropping the mic completely from this budget. I'm going to instead get all my video stuff up to snuff, so I'm looking now at getting the Cavision MB4169H-2 16:9 Hard Shade Kit for the XL2. I'm a bit new to the whole filter thing, is it just like Gels on spot lights? |
filters are not just about adding colors. Yes blue grads, and sunset grads will make sky shots pop. However the filters you will grab first are going to be ND filters, both grads and solids, as well as a good pola.
whatever the filter 4x4 and 4x5 matte box with 2 trays is going to provide you with a lot of options. good luck |
Before you buy at vistek, you should check with henry's photo in toronto. also check with don's photo in Regina, Saskatchewan. Don's will order in almost anything and they are generally very competitive. Just a thought.
I checked vistek site out and they are definitely more expensive than you need to pay. |
Figured I'd post an update:
Gone with the XL2 from Don's Photo here in Brandon, Manitoba. Also getting the Canon filter set through them (I'll get better filters as time goes on). Ordered the EDIROL R-09 from Vistek along with a ton of accessories (the table stand & case, the mic set and the carrying kit for the whole kit and caboodle. So now I have a more flexible audio option.) I'll invest in a matte box before the end of the year, and I'm looking into a good Tri-pod very soon (since I've relied heavily on a tri-pod to this point, I'll want to get a good one to go with the XL2.) Going through Don's Photo for that (those guys rock! Love the service!) I'm also going to try and expand my shooting now to include shots from the shoulder (since I used to have a difficult time keep things stable with my tiny sony handycam). I've only received the camera so far, but maaaan, is it nice. Now I just need to familiarize myself with it. |
Regarding the tripod, I couldn't recommend this combination more as the best bang for the buck. It's the Manfrotto 525MVB sticks with ground spreader, plus the 503 Pro head. http://www.bhphotovideo.com/c/produc...gs_Black_.html |
Hi Jack,
I wanted the Canon filter set to hold me out till I can get the money together for the matte box. All of the current gear (except the tri-pod) were being purchased for me as part of a contract agreement (I do work for them, they buy the gear I need to do the job). Plus it doesn't hurt to have them around in case something happens to the mattebox down the line and I need a fall-back solution. I like to hedge my bets and be over-prepared where I can :) |
$900!? What will I lose by downgrading from this? |
Tell you what, without me giving you a long spiel about the benefits of this, or the drawbacks of that, take your XL2 to your local camera store and try out the cheaper stick/head combinations. You wont have the complete range to play with, I shouldn't think, but probably enough to get the idea. The XL2 is heavy enough to need strong, rigid sticks, and a true fluid head for smooth panning. I'm just an amateur. There are pros here that have spent thousands on their support systems. |
