Short component cable for H1/A1 for LCD monitor
Anyone know of a solution? We have the component cable that comes with the cameras, but it's MUCH longer than we need when the monitor is 6" above the port at most.
By the way, if anyone has a chance to check out the Panny LH80 monitor...it is killer. The focus on red is an amazing feature. Thanks for any ideas! Kevin |
Hi Kevin.....
Do a search for this Q Kevin, this came up (somewhere on DVinfo) not that long ago and seems to have been successfully solved (from memory).
CS |
Kevin: I've looked for this too, let me know if you find anything (I use an M2 occasionally, and that long cable is a major pain)..
Got it..........
Thanks, Chris, but I had already found that one. I was hoping there was another solution out there in this large world of ours. :-) I can't believe that's it, but so far, it's all I found, too. It has RCA ends...I could use that with adapters, but was hoping to find a D-4 to BNC component.
Thanks. Kevin |
