Final Cut capture problems with XL-h1a
I've had this camera for 7 months now and have not needed to capture any footage thus far as most of my work is handed off to others after a shoot.
Today I've spent hours searching for an answer as to why Final Cut will not initialize the camera as a capture device when in HDV mode. I read through a thread that had members suggesting that I shut down FCP (version 6.0.5 by the way) and have the camera turned on when I restarted the program. That hasn't helped. My Audio/Video settings have been changed to just about every combination I can think of and still FCP will not recognize the camera as a deck. My current settings are as follows: Sequence Preset: HDV - 1080i60 (Footage was shot with this setting) Capture Preset: HDV Device Control Preset: HDV Firewire Basic My camera is connected via firewire to the front of the Mac G5. I'm dying here! Any ideas as to what the problem may be? Thanks. |
Tyge,
even if your Audio/Video settings are correct set-up, I've found that I have to run the Easy Setup every time I want to capture from HDV. So my procedyre is as follow: In Final Cut Pro-menu, choose Easy Setup. Set Format to: HDV, in the USE-window choose HDV-1080i60 Firewire Basic, then click Setup Then from File-meny, choose Log and Capture. Final Cut should now recognise the camcorder and be ready to capture. I have the same FCP version as you, on a Mac Pro 2x3.2 GHz Quad-Core Intel Xeon. Hope this helps? |
I just tried that and it didn't work. When I click setup FCP throws a popup that reads it can't locate the firewire device.
Thanks so much for your insight. Still searching for an answer to this problem. I did capture some footage in another project set to DV NTSC. The footage is SD I suppose and 853x480 instead of 1440x1080. So, I know my firewire port is not burned and is working. I wonder if there's a setting on the camera that I may have set that could be causing the HDV capture problem? |
I have the "old" model of Canon H1 and this is what the manual says:
If your tape consist of HDV 1080i60, ensure that in the Signal setup menu on your camcorder, says Playback STD set to HDV. Important: make sure that HD Down-Conv is set to OFF! |
Mr. Per Johan Naesje, you sir are a genius! That was it. I had to change both of the menu options. As soon as I did I successfully captured my first HDV clip from this camera. Thanks so much for your help.
Am I supposed to be using a different kind of Firewire cord than I used with SD cameras? I can import into iMovie HD without issue, but I shot at 24f and iMovie doesn't import at the correct frame rate. Anybody have other suggestions? Thanks. |
