Here's What Scott Billups Thinks Of The Canon Xlh1..
If you know who Scott Billups is ( PIXELMONGER.COM ) , and there is no reason why some of you shouldn't, then you will find this very interesting about what he said on the Cinematography board list about the Canon XLH1 he is testing. Scott is one smart individual and knows his $%^#.....
I don't believe most here could disagree with Scott and his experience.... Here is a link: http://www.dvxuser.com/V3/showthread.php?t=45971 Quote #1 from Scott Billups Tuesday,*January*31,*2006: CML text removed by admin -- see note below Quote #2 from Scott Billups Tuesday,*January*31,*2006: CML text removed by admin -- see note below |
Don't you think the P+S is just making the image softer like all 35mm adapters, not just because cine lenses arent as sharp as HD lenses? I'd like to see a cine lens directly mounted onto an XLH1, without the P+S vs. one with an HD lens.
1/3 imager specs are very tight. Cine lenses are made for a much larger target zone. Regardless; Scott Billups remarks about the H1 ( like the 50,000 dollar comment says a lot.
Please DO NOT cut and paste material from other web sites into DV Info Net -- to do so is a violation of the intellectual property rights of that other site, in this case CML. Please just post a link if possible. In this case you have to first register with CML in order to view their content. The link is:
http://www.cinematography.net/ -- from there, go to: http://ls.cinematography.net/read/?f...ml-hd-prosumer To cut and paste material from CML into here is a clear violation of their Terms of Service: http://www.cinematography.net/condit...membership.htm Let's all please respect each other's copyright. Thanks in advance, |
Fine, I will get permission from Geoff if that makes you happy......:-P
