Lens Question...MAJOR ZOOM NEEDED
Hey, this may seem like a bizarre question but someone I know is looking to pick up a new camera, but needs a huge zoom. He's currently using a JVC500u with a 19x lens with a 2x-doubler giving him approximately 40x zoom which is used contstantly. Seriously the least he's ever zoomed in is like 20X. I was thinking about recommending him the XL-H1 and possibly the EF-adaptor and a L-series Canon lens, but the question is...which one? What is the crop on the XL-H1 (if any), by that I mean on a non-full frame DSLR its a 1.5X crop.
The other camera I had considered recommending for him was the JVC HD110/100/200 group, but to get the 40x lens (19/20x with doubler) would be $1200 for the 1/3 to 1/2" adaptor and then a $6k-$9k lens. the budget is close to $10-$12k but he can go over a little if he needs. |
I believe the crop is 7.9, so essentially it make the lenses telescopes. I don't think that he will be complaining about the range.
Noha, your friend must be doing some wildlife stuff or looking at girls ;-)
Well, to the point. The XLH1 is well suited to use external ef-lenses. The multiplay factor is 7.2 so a 300mm gives you 2160mm while a 500mm gives you 3600mm! One thing to note is with such a focal lenght you will have some haze from the air. I have been using a Sigma 300mm f/2.8 and a Canon 500mm f/4.0L with good results on my XLH1 Note that high class lenses will give you better results than cheaper one. Also zoom lenses tend to be a bit softer on the telephotoend than prime lenses. Good luck! |
The Fujinon lens he uses now is a 6.? to 128mm so theoretically a 24mm-105mm L lens would be even more zoom than he's got now? 105 X 7.5 = 785mm so that would be like way more than enough right? He's shooting a stage from about 200-300 feet away
The 300 mm just looks like a 2160 mm on a 35 mm SLR camera. You can get the same tele lens on your 35 mm camera by cutting the negative with a pair of scissors ... Noah, A continous zoom range of 40x is huge and expensive. It seems your friend is looking for a long focal length and not the big zoom range. So why not put on a zoom with a smaller zoom factor but long focal length? Then the lens will be much cheaper and better too because those big range zooms are always compromises, especially at the "ends". |
I would do that, but neither he nor I have been able to find any lenses that are telephoto enough. Every 1/3, 1/2, or 2/3 lens I've seen starts at between 6-8mm with varying levels of furthest focal length, hence the prediciment. It sounds like with an EF adaptor, he could get a Canon L-series lens in the $1000-2500 range that would do the job instead of spending like $20k on a camera and lens that he won't use the full capabilities of.
How much more range would a 500 mm lens give over the zoom lens which comes with the H1?
Thats an easy calculation: 500 mm / 108 mm = 4.6!
Thank you! I didn't realize it was that simple.
