Monitor bracket question for Adam
Adam, I just read your article in the Watchdog, "Adding an LCD Monitor to Your XL1." I was just getting ready to try and have a bracket made to hold my LDC monitor when I found your idea...which is much simpler than what I'd planned to do. One thing I'm not clear on from the photos and explanation...is that one screw that goes through the bottom of the bracket, through the MA-100 and attaches to the base of the XL-1? Or is it a bracket with a screw on one side (to attach to the base of the XL-1) and a socket on the other (to attach the bracket screw to it)?
Thanks. |
On the MA-100 there is a flat head screw that you tighten to hold the MA-100 in after you click it into place. I took out that screw out of the MA-100 and replaced it with a screw that came with a bracket kit I bought. (no idea what brand or make that was). That new screw had another screw hole on top of it so you tightened it by turning the sides of it. Original, I'm sure this screw was meant to screw into the bottom of a camera while holding the pre-made bracket. I of course wanted to keep the camera base free for a tripod so I added to the MA-100 instead. I also had to completely take the MA-100 apart. When I'm not using the bracket and view finder, that new screw still stays holding my MA-100 in place but it still has that extra screw hole on the outside of it.
I think that makes sense? Hope this does... |
Yep...that clears it up. Now I just have to figure out where I can find a screw like that. Would be much simpler than having a metal foundry cast the bracket I've drawn out. Too bad nobody markets something like this.
Thanks for the explanation. I'll let you know if I find the parts and get it put together. |
No problem!
Nice chatting with you! |
