xl1 underwater
I have seen a few people discusing their underwater packages, and was looking for some advice.
Has anyone tried the Aquavideo brand of housing? Does anyone know of a housing that is rated to at least 100ft, costs less then $3000.00, and weighs 25lbps or less at the surface? Any advice on housing units that you have used would also be greatly apreciated. Thanks in advance |
What ever housing you buy please be very careful about closing the ports on the housing. I got one brain of sand in the "O Ring" grease and my $600 strobe injested salt water at 80' and fried itself.
Grayson |
Thanks grayson, That is always a fear when I'm using my still camera and I know it will persit when I get something for my XL1.
That was part of the reason I was questioning the aquavideo housing. Seems they use an x-ring instead of an o-ring. They say this creats two seals and helps to eliminate the chance of a single grain of sand messing with the seal. |
I toyed with the idea and was considering a Gates housing. But they're really costly and I don't know if I'd want to risk an XL1 underwater. Not just yet, anyway.
But the trick to o-rings is as Grayson said: keep 'em clean. There should be just enough silicone lube to make them feel slick, but not enough to actually see. It's just there to allow the o-ring to seat freely. Too much grease and it'll actually prevent the o-ring from seating fully in the groove of the housing and cause a leak. Excessive grease will also prevent you from seeing debris that could cause a leak. Even a stray hair can let water stream in when you go past one or two atmospheres. The worst flood I've ever heard of was a Betacam in a custom housing. It imploded at 60 feet. Dean Sensui Base Two Productions |
