25 fps higher quality than 29.97?
Hi all,
At the CanonDV site - www.canondv.com - the following claim is made in promoting the virtues of the XL1 PAL: "A slower playback speed serves a higher quality picture" Would someone explain this to me? I could understand the claim that a greater number of pixels in PAL format might yield higher quality results, but is it also true that slowing frame rate somehow improves picture quality? Thank you. Tim |
As I understand it, PAL gives more scan lines lines for improved vertical resolution with the same horizontal resolution. Also, the PAL signal format gives more reliable/repeatable color information. The 25 vs. 30 fps frame rate allows the higher vertical resolution within the same bandwidth.
