-   Canon XL1S / XL1 Watchdog (https://www.dvinfo.net/forum/canon-xl1s-xl1-watchdog/)
-   -   dc out terminal (https://www.dvinfo.net/forum/canon-xl1s-xl1-watchdog/65-dc-out-terminal.html)
Manuel Albarracin September 20th, 2001 11:21 PM
dc out terminal
thank you for the reply mark
please explain how the MA-100 or MA 200 use this dc out terminal. Also can I use it to power a lcd monitor or lights perhaps.
Don Palomaki September 26th, 2001 05:05 PM
dc output terminal
No to powering lights or LDC panel. Both lights and LCD panels tend to draw a lot of current (on the order of amps) and tend to use higher voltage. At best you may blow an internal fuse and worst case you could blow an internal voltage regulator chip.
The MA100 (and MA200 no doubt) contains small signal amplifiers that convert unbalancd input to balanced output. It draws a very small amount of +5 volt DC current from the dc output terminal.
