external microphone for canon XL2? at DVinfo.net
Old November 14th, 2008, 11:17 AM   #1
Hi
What do you think for an external microphone:
Sennheiser ME66/67 and K6 for the Canon XL2, i'm lookink for a good microphone not too expensive.
Gilles
Gilles Debord
http://www.wwvideo.tv
Gilles Debord is offline   Reply With Quote
Old November 16th, 2008, 01:58 AM   #2
Hi Gilles,
Well, it depends on what you are trying to accomplish. Assuming you're convinced you need a shotgun to replace your on-camera mic, you can learn about various shotguns here:
DVFreelancer Article: Shotgun Shootout | Digital Video Freelancing on the Net
Good luck, Michael
Michael Nistler is offline   Reply With Quote
Old November 16th, 2008, 04:34 AM   #3
Thank you Michael
I need a shotgun for wildlife video only
Gilles Debord
Old November 19th, 2008, 02:27 AM   #4
Mics - for the birds, animals, etc.
Originally Posted by Gilles Debord View Post
Thank you Michael
Okay, it's always helpful to give this kind of info up-front. At any rate, you'll probably want to use a bazooka mic or appropriate mic with a parabolic disk (I assume not a shotgun for parabolic due to directional limitation).
Here's a few useful links:
Animal Sound Recordings
http://www.dvinfo.net/conf/all-thing...ooka-mics.html
You might also want to search the internet for appropriate terms.
Regards, Michael
Old November 19th, 2008, 02:17 PM   #5
DVCreators.Net
Here is an interesting article I found useful. Field Techniques ; Macaulay Library
It all comes down to budget. You can get some really nice stuff for general recording of wildlife sounds for great prices these days. It just that extra little bit of quality that gets expensive quick. IE, a field mixer for ultra quiet pre-amps, and a parabolic dish.
For a pretty decent system that would work well, I'd look at the Rode Blimp for $299 along with the $699 RODE NTG-3 Shotgun Mic. That's pretty sweet package for under $1k. But, you might also want to research some of the long shotguns, check out Audio Technica's monster BP4071L Line + Gradient Condenser Microphone
Guy Cochran
Old November 20th, 2008, 02:56 AM   #6
Gilles,
I use Sennheiser ME67 + K6, in pair and single for my wildlife recordings. I'm very happy with these mics.
I've used them for years with XL2 and H1 (Canon) and they work very well in most conditions. Even in wet and cold conditions. Most often I connect them with a 24 feet cable. It's also very important to monitor your sound recording through earphones when recording.
A trick could be to use them in pair and different recording levels (one high and one low) in that case you you can switch between the sound track in post using the most appropriate regarding levels!
I always use a Rycote softie Rycote | 29cm Medium Hole Softie | B&H Photo Video replaced the handle with a tent stick and put them to the ground, works very well!
Here's a couple of samples:
video-film.no Tiurleik (Capercailzie Mating Game)
video-film.no UWOL-challenge 4 (Brown Bears)
Note: the sound due to compression is not as good as my original file, but you might get an impression?
- Per Johan
Last edited by Per Johan Naesje; November 20th, 2008 at 04:25 AM. Reason: Edit misspelling + add text
Old November 20th, 2008, 03:53 PM   #7
Thank's a lot Michael, Guy and Per Johan for all the information. The idea to use it in pair seems to be nice.
Another question is there a big difference between the Sennheiser ME66 and ME67 ? i think it's the diagram.
Gilles Debord
Old November 21st, 2008, 07:38 PM   #8
The ME67 is longer and much more directional than the ME66. I would think the ME67 is what you'd be looking for for wildlife footage, although, honestly, if the subject is very far away I don't think anything really is going to help. I believe most of the wildlife footage you see on television is foleyed. The ME64 is a great upgrade to the stock mic on the XL2, and it's small enough to fit into a standard carrying case. The ME66 and the ME67 will probably have to be refitted every time you take the camera in and out of a bag.
Marco Leavitt is offline   Reply With Quote
Old November 23rd, 2008, 10:10 PM   #9
I've been reading comparisons between various external shotgun mics, but one comparison that never seems to be made is that between the Sennheiser or Rode or what have you, and the actual stock mic that comes with the XL-2 or H1.
Everyone seems to assume that the stock mic is just bad. Is it? If the audio from
these other mics has to be cleaned up in post, too, then what justifies the added expense, and the trouble of having to carry around yet another piece of equipment with its attendant wires, etc.?
Steve Siegel is offline   Reply With Quote
Old November 24th, 2008, 02:18 AM   #10
Well, I will not say it's bad but it's position is very bad, picking up all the bad noice from the operator of the camera!
My opinion is that it's much better to use external mics and particulary when you are sitting in hides you can put them in front of you. This way you can better control what kind of ambient sound you got. With long cords you may put the mics almost where your target are (I believe Gill will use this set up mostly for wildlife recording?) Using huge telelensens gives you a very narrow sector of picture, recording most of the sound from this sector will only do if you are using shotguns like ME67 (or other equal brands).
If the audio from
I seldom have to clean up any thing in post except for adjusting levels, which you have to do with any audio track! My goal is to get the best ambient sound when I'm at location.
As Marco says, wildlife docs is often foleyed. Sound engineering is a profession wich take years to get a good grip on. Therefore I prefer to do as much of the sound recording out in the field. Think this is what works best for me, IMHO!
- Per Johan
Per Johan Naesje is offline   Reply
