Help ... I have a dust into my viewfinder XL2 at DVinfo.net
Old July 20th, 2009, 11:26 AM   #1
Hi !
Well Ive got something in the viewfinder ... behind the first glass (plastic glass) when you know that we opened the viewfinder !
I can 't remove this dust... I look at the Canon manual but it is not that ,its not at the same place ...
I need to show you where but i dont know how (image) ?
Somebody has a way of removing that ... I give a knock on the plastic glass to move the grain of dust on the sides of the viewfinder ,but thats not work !...
Please
Daniel
Kijiji : Ouvrir une session
Dan Lim is offline   Reply With Quote
Old July 20th, 2009, 04:43 PM   #2
Dust inside the viewfinder (behind the outer plastic element) if minor can be left alone as it will not affect the actual footage, but if it is a big clump that is annoying to view through then it'll need to be taken apart and reassembled.
Completely remove the rubber eye-cup first. The plastic viewfinder eyepiece can then be unscrewed and taken apart to allow better access and clean behind the outer element but it can be a bit fiddly to fit back together.
www.WILDCARP.com
www.NIKON.me.uk
Tony Davies-Patrick is offline   Reply
