Same application for premiere and vegas?
Hi,
Some time ago I have installed a trial version of Aspect HD and I was blown away by the performance increase on premiere. Since then I've been toying with the idea of buying it. But more and more I see my work divided between Vegas and Premiere (the ability to have such an efficient lossless codec that allows me to move between these 2 application is also one of the reasons for buying). Do I need to buy a different copy for each software or will the same copy work for both? |
You only need Aspect HD to work in both Premiere and Vegas -- although we don't acclerate Vegas as much, the quality benefits and camera format support still applies.
Thanks for the prompt reply, David. That is excellent news. We might be doing business real soon :D
I use both Premiere and Vegas as well. Thanks :) Eric |
We not focus on SD as that is pretty easily handled by modern PCs. So can edit SD project using CineForm, but you would need to determine for yourself if it enhances the workflow enough over DV.
Oh okay, thanks for the quick reply David :)
I tried a trial of Aspect HD last year, but couldn't find a way to use it for SD projects. Is there a preset that would work or a link to a site explaining how to do it? |
Create your own preset for SD, takes only a couple of minutes.
Alright, I'll give it a shot, thanks :)
