Editing the Meta-data in AFX
Hi
I own p2k, shooting on the SI to Cineform RAW. In PP2 i can change the metadata and play around with it to my heart's content, change different look files and assign new looks. yet, in Afx Which is where i really should be doing that, i cant find any tools to edit the Meta data other then turning it off any reason for that?solution?workaround? Thanks Lior |
The problem is while we could do directly it in AE 7.0, AE CS3 removed the feature we use to add custom file control / importer features. Working on solution for all PC and Mac tools. Workround for now is to continue using Premiere for metadata tweaks.
so is there a working solution if using AE7?
if so i'd love to try it out.. If not, is there a rough estimate to when there will be? Thanks Lior |
Limited in AE7 and we are not enhance that at all (likely obsoleted in the next version.) We are working on stuff, can't tell you how soon.
