the requested look up key was not found
Hi
does this ring a bell (not sure its a cineform problem) trying to import a PP2 project into afx. importing is ok. when re-opening the project i get this error message: "After effects error:an inspecified AVI or Directshow error had occured.the requested look up key was not found in any active activation context (1). (53::33)" any idea? Thanks Lior |
Hi Lior.........
Can't help with your current problem.
BUT, could you either click the little triangle in the lower left hand corner of you original post OR click on "Contact Us" right at the bottom of every screen and get your current location updated? Bit of a bugger not knowing where a poster is, due to hardware/ software availability issues amongst other things. Thanks. CS |
