Aspect HD - export issues from After effects 7.0
Hi everyone,
I have been using Aspect HD for a while now and have been very happy about it. However I am struggling now with an issue/error when exporting from After effects. I edited 720p 24p material in Ppro, copy/pasted everything in AE, did some color correction. I then add to render queue the composition, select Cineform as the codec and try to export to 1024*576 (PAL DV widescreen square pixel ratio) but then I get an error message saying "unsupported height". To what size should I export my video if I want to keep the 16*9 ratio? Exporting to 720*576 works but the ratio is wrong! Anyone faced the same issue? Thanks Simon |
Can you create a new PAL DV widescreen comp in AE, add your 720p clip to it and resize the clip to fit the PAL DV widescreen comp?
And then export that? |
