Work flow from Serious Magic Ultra-2 with Cineform AVI files
I have been capturing HDV MPEG-2 directly from my Canon XL H1 to my PC via P-Pro. I then convert from MPEG-2 to Cineform AVI files via my recently purchased Aspect software. I then import a Cineform AVI file into Serious Magic Ultra-2.
I'll write the next part in steps: 1) Via Serious Magic Ultra-2 I key out my green screen. 2) Via Ultra-2 I export the keyed video using "Directshow AVI", "Uncompressed" at 32bit - (This is the only way that I can save it with the keyed alpha channel). This is the procedure outlined in the Ultra-2 manual too. 3) I then import into P-Pro CS3 and insert my background over the alpha channel. The problem is that the sample rate in Ultra-2 at 32bit is very high. A Cineform AVI file that starts out at say 200Meg ends up at 2.5 Gig after I export from Ultra-2 at 32bit. I'm not sure if I'm gaining anything at the high sample rate. There simply is no other choice. If you want an alpha channel, according to Ultra-2, you have to export your key's segment at 32 bit. I did try to convert the Ultra 32 bit export back to a Cineform AVI file. The file size reduced considerably. However, I lost my alpha channel. Can anyone recommend a better work flow? Thanks... Tim Bickford |
There are Ultra issues, they simple don't support compressed exports with alpha channel, even though CineForm compression (and one a couple of others) can handle that fine. I can't think of a work around short of recompressing the uncompressed file in AE.
Dave-
Thanks... I gues I can try my luck with the HUGE avi files in P-Pro-CS3. I'll see what happens. Can you give any advice on an alternative keyer? Thanks again! |
