REMASTER edl filter
Hi we are testing the workflow for RED. We transcode rushes for edit qith CF express files. Then we want to filter the MASTER TRANSCODES with an edl coming from final cut sequence. We canīt do that could you enlight us about this workflow. It will be great if we can render to full resolution only the edl footage.
thanks in advance. sebastian toro sinsistema.tv bs as , argentina |
In ReMaster select all your original footage. Once it is in the work queue, select all the clips using "Select All" from the edit menu. Then choose "Filter using EDL.." from the edit menu/ ReMaster will show a standard open file dialog, open the EDL file created by FCP.
Only clips in the EDL will remain in the work queue. |
Edl remaster
Thanks Craig, it works very well...
What about the SI-2k RAW .avi conversions in MAC.? Thanks in advance Sebastian toro |
