No Known Conversion with Neo Scene
I downloaded the Neo Scene trial and I'm capturing clips using imovie 08 from my HV30 to an external firewire drive. Everytime I try to convert the clips with Neo Scene I get a message stating "No Known Conversion for Selected File" with the file name and (mv/icod). Can anybody help me out here or point me in the right direction to get this thing working right? Thanks.
You want to be converting M2T files. I'm not a Mac guy, so I'm not sure whether IMovie supports M2T captures.
I thought Neo Scene was suppose to work with Imovie? Or is that only when the files are captured by another source then converted by Neo Scene to be used within Imovie?
I appreciate your help David. |
Yes, not the Mac guy. I know the output from Neo Scecne works well in iMovie, which all the AVCHD users have no issue with (file based conversion in Neo Scene.) With HDV there is still a capture process that happens first. It has been written up before, but finding the info is the trick.
File a ticket or ask Craig Davidson (he is on these forums.) |
So I guess capturing with Imovie is out. Can you recommend another form of capturing from the camera?
I tested with the HV20 and our old Mac Pro (dual-dual). If you use QuickTime to capture from the camera, select "Camera Native" That will create a QuickTime mov encoded as HDV. NeoScene can convert that.
