Cineform and PPro rendering time at DVinfo.net
CineForm Software Showcase
Old April 22nd, 2010, 06:04 PM   #1
Images: 1
For every 1 minute of Cineform timeline, it takes 10 minutes to render out for me. Are there any plans to improve rendering speed? What are other people experiencing?
BenWinter.com
Ben Winter is offline   Reply With Quote
Old April 24th, 2010, 03:18 AM   #2
In CS4 i get about 8 minutes.
However, in CS5 its close to realtime on the same computer with NeoHD 4.2! :) *hurray*
I have heard lot of people that get realtime in CS4 as well with the Intel i7 processor. (I currently have 2 x Intel E5450, ie not from the Nehalem family and that may explain the render times for me in CS4.)
/Roger
Roger Averdahl is offline   Reply With Quote
Old April 24th, 2010, 05:37 AM   #3
Render the timeline or export to....
Old April 24th, 2010, 09:11 AM   #4
My interpretation of Ben's question is: CFHD > CFHD
My example is CFHD > CFHD as well, ie CFHD media on a Timeline that i render out to a CFHD file.
/Roger
Old April 24th, 2010, 11:59 AM   #5
Try not rendering. Premiere Pro doesn't really know whether the video needs to be rendered or not. I ignore the yellow and red color bars, and everything just works. I open a project in Encore and import the Premiere timelines directly. Transcoding doesn't happen until Adobe Media Encoder opens during DVD and Bluray authoring, which is much faster than realtime for my Core i7-920 12 GB Windows 7-64 machine.
John Quandt is offline   Reply With Quote
Old April 24th, 2010, 12:06 PM   #6
I'm exporting a 20 mins clip to CFHD file and Adobe Media Encoder is only using 30% of my CPU? How come its not maxed out?
David Dwyer is offline   Reply With Quote
Old April 24th, 2010, 12:10 PM   #7
I'm using Windows 7 64-bit with 12 GB of RAM. When I transcode for authoring, I experience 85% utilization on 8 cores. What is your configuration?
Old April 24th, 2010, 12:14 PM   #8
Windows 7 Pro 64bit
AMD quadcore 2.1
8GB of RAM
Old April 24th, 2010, 12:17 PM   #9
That sounds pretty good. My hard drive configuration is 750 GB 7200 rpm boot drive and 1 GB 7200 rpm video drive, both eSATA. All Adobe applications configured to use the video drive. I'm editing Sony HDV and authoring both DVD and Bluray using Encore.
Old April 24th, 2010, 12:28 PM   #10
HDD Setup is
OS 74GB 10k RPM SATA
MEDIA 2*400GB RAID0 7200RPM
SCRATCH 750GB 7200RPM
Old April 24th, 2010, 12:36 PM   #11
I just tried the same export, and I got between 30 and 40% utilization, so your result seems to be typical.
Old April 24th, 2010, 12:40 PM   #12
Hmm not sure if this is causing it but I reinstalled Windows 7 after using the RC for a while, the PC probably needed a reinstall anyways! After reinstalling CS4 and I created a pre-set for Cineform, Desktop editing, 1920*1080, square pixels and for fields I picked progressive.
That would be fine but my footage is interlaced.
I've have edited this 20 mins DVD and export took ages (5 hours to create a CFHD master file) So I used dynamic link to export it to encore and create a DVD but the footage looks all strange with wavey lines of panning.
Now I'm creating a new project with upper fields and rendering the footage again to hopefully fix my DVD issue.
Would creating a progressive project and interlaced footage cause the slow time on the exports?
Old April 24th, 2010, 12:55 PM   #13
My experience has been to keep the original file settings, whenever possible, which is 1440 x 1080 x 60i for me. Changing the video resolution just slows things down with no appreciable improvement in output quality. My timelines match the input format above. I use dynamic link to import the timelines into Encore, so I don't do any transcoding until the final burn, where I just let Encore control the transcoding and burn.
Old April 24th, 2010, 01:01 PM   #14
Yeah the fields was a error. It should of been called my YouTube Preset.
I have 2 cameras the Sony Z1 and Sony CX105. They are both 1080i but Z1 as you know 1440*1080 PAR 1.33 and CX105 is 1920*1080 PAR 1 so I use HDlnik to resize Z1 footage to 1920 so its easier on the editing.
I'll be testing the export again about an hour after this project renders in PP.
Old April 24th, 2010, 02:58 PM   #15
OK,
10 min timeline takes 8.41 minutes in CS4,
in CS5 it takes 6.21 minutes to encode on my machine (i7/940/12 gig/raid0) in direct export. Just NeoScene no NeoHD.
Ann Bens is offline   Reply
