Invalid Activation, Trial Running Out-Help, help
Upgrading from PHD 4.x to Neo4K v. 5.
Uninstall PHD (but not deactivated), N4K Install went fine, N4K working fine with CS5, received serial #, received activation key, but get error message "activation key invalid". Uninstall, redownload N4K build 256a, install, same problem. Filed Trouble Ticket #611-8307672 & has been in a few days now, but no helpful activity. I don't know if I need a new SN, new Activation Key, or what. I know support is jammed up, and I normally wouldn't sweat this, but my trial period is running out in a couple of days leaving me dead in the water. Would appreciate any help. Thanks |
just get same error now with same install.
deinstalled neo5, reinstalled phd4, deactivated phd4, installed neo5, same problem. reinstalled and reactivated phd4 until problem is solved |
I no longer have CS4 on this computer; also am in the middle of a couple of CS5 projects. It's pretty weird- I've never had this sort of activation problem with any CF product before. |
No PHD4 has no 64-bit components, other the VFW codec (which will work -- but only in the desktop modes.)
That may not be your problem, but it's worth a shot. |
found solution. Stupid me has installed Neo HD instead Neo 4k (web site and mail are not very clear about that )
still under CS3. |
I clearly have Neo4K v. 5 installed, also using Explorer browser, but the activation key simply will not unlock the software.
I've had no solutions from support, so they must be stumped as well. Could I be the only one with this problem??? There has to be a way to fix this. |
Support will be back up to steam tomorrow, so it will be sorted out soon.
Surprising solution, but worked like a charm.
Many thanks |
Bob,
Please share what happened. Thanks. John |
Support had me type in my registered owner name a little differently, same serial #, same activation key, and activation was finally successful.
My guess is that it was some sort of security work-around. I still don't know what the original activation problem was, but it's history now :) |
