build 522.282 First Light Bug - White Balance
White balance not updating LIVE.
Clicked on white balance, enabled in global controls, enabled in clip controls, adjusted values, No response in image until i click on and off the global or Clip control. minimizing and maximizing the software is now working great! |
Release version is 5.2.2.283, is doesn't have that issue.
wow, that was fast! thanks!
previous build also had the issue of clip lengths. 1. imported 4 clips of different lengths 2. scrub individual clips on the timeline -short clips appear to be longer, but freeze frame 1/2 way down the timeline scrubber. -long clips cannot scrub through the whole clip, scrubber hits the end of the play timeline before the clip actually ends. |
Haven't fixed that, but it is easy to work around.
cool, what's the workaround?
I have some clips that are 10 mins, and other that are 4 minutes, the scrubber on the 10 minute clips stops at the 4 minute mark. The only way I can reach the end to drop a keyframe is by pressing play and sitting and waiting for the clip to play through to the end. |
also, what's the link for the 283 build?
Thanks! |
clip on another clip and return, fixes the length issue. 283 is available from cineform.com.
click on another clip and return?
I'm not sure what that means. 4 clips are in my bin. I have a long clip clicked on. It only plays 1/2 the clip in the scrubber. I click on a shorter clip. I can scrub 1/3rd of the way down the scrubber and the image freezes in the player if i go past the 1/3rd mark. I click on the longer clip again, and it still only lets me scrub through 1/2 the clip before it hits the end of the timeline. Am I misunderstanding what you said fixes it, can you clarify? Thanks David! |
Doesn't do that here. The once in a few weeks of use, a clip something scrubs short, and a clip refresh (clicking on another) solves the issue. If you are seeing other please work with support as clearly something is causing anything that can go wrong on your system to do so.
