Beta for the long weekend.
We had a lot of internal builds in the last few weeks to solve some corner case conditions, so it is time roll all these changes together into a public beta. While this beta is mainly bug fixes, if you have the time and are not in the middle of an important project, please give this build a try.
Thanks. NeoScene http://cineform.com/downloads/NeoSce...286-101124.zip NeoHD http://cineform.com/downloads/NeoHDv524b286-101124.zip Neo4K http://cineform.com/downloads/Neo4Kv524b286-101124.zip Neo3D http://cineform.com/downloads/Neo3Dv524b286-101124.zip Release notes from the NeoReadMe.rtf: Fixed: An SDK Licensing error within the upcoming Vegas 10.0b Fixed: Last line color was incorrect on converted interlaced sources. Fixed: OpenGL selector in FirstLight. Fixed: DPX2CF for large TIF files. Fixed: BlackMagic frame rate naming in HDlink capture. Fixed: many smaller bug fixes. |
With this latest N4K Beta I suddenly seem to be having PPro CS5 lock ups/app crashes when using DL and AE.
I've rolled back to the last release version- we'll see if that cures it. I don't recall having any problems with it previously. |
I don't think anything has changed in that area, we will check on other reports.
Dave,
The Neo4K beta above is wrong. Its showing up as Neo3D after install. Can you provide correct link? Frame rates are still showing up with incorrect labels in HDLink with Decklink cards. Thanks. |
For some reason Neo HD 5.2.1 and 5.2.2 cause Vegas 10a to crash when I render from the timeline. It used to work - most likely with the version of Neo HD I had when I installed Vegas 10a a month or so ago (don't have any prior Neo HD version to try).
However, I tried this Beta 5.2.4 and Vegas 10a not longer crashes during rendering. Unfortunately, when I open up the rendered Cineform avi in FirstLight, it says the clip is corrupted and won't open the clip. It plays back fine in Windows Media Player. My only other observation is that all three of the above Neo HD versions pause halfway through installation says that the Microsoft redistributable can't install on drive j: due to insufficient space. I don't have a drive j: I do see the Microsoft redistributable window pop up a few times, but it is only one of them that seems to get stuck on drive j:. Not sure if it is related. |
