New Mac Betas
NeoScene http://www.cineform.com/downloads/Ne...171-110128.zip
NeoHD http://www.cineform.com/downloads/Ne...171-110128.zip Neo4K http://www.cineform.com/downloads/Ne...171-110128.zip Neo3D http://www.cineform.com/downloads/Ne...171-110128.zip Release notes from the Neo3D ReadMe.html file: Codec: Fix issues with decoder not always recognizing a new clip and loading the metadata. Codec: Fix issue where 3D adjustments on side-by-side display were unstable. StereoModeStatus: Correctly show the anaglyph-optimized setting. Was leaving it checked and also showing some other mode checked at the same time. ReMaster: Address location of files when selecting using FCP XML. Fixed a problem where subclips were not always found. ReMaster: Reduce the memory needed to load thumbnails to allow more files to be open at a time for import. FirstLight: Change the responsiveness of the Lift controls to match the PC. FirstLight: Fix memory leak issues in loading of thumbnail images. FirstLight: User Interface cleanup for new stereo mux panel. Once again, please post any feedback on this thread. Thanks! |
Any idea if the Premiere and After Effects exporters will make it to this version of the product?
You can safely use the Quicktime exporter for Mac. We fixed the issue for AE so that the trillions+ colors option should now be working for deep pixel exports -- with that there is no need for additional exporter.
That's great news. Does the same go for exporting from PPro or Adobe Media Encoder?
If so, then the main features of this version of the product are pretty much done aren't they? Remaster and First Light are working, the Premiere Pro importer is done, and 10bit files can be exported to use as intermediates, or for archival. |
