Feature Request....PPRO Fullscreen monitor selection
I have 3 monitors and 2 video cards....one a quadro driving a dreamcolor through displayport
and the other is a 470 driving 2 dvi's Inside a ppro timeline when selecting a fullscreen output....i can assign it to any monitor.. However when using a cineform timeline....it seems only monitor 2, becomes the fullscreen output. I need my dreamcolor (monitor 3) to go through my quadro's display port for 10 bit out...so I really don't want to mess with the setup I have currently Would it be possible to add the option to cineform sequences playback settings to have a choice of which monitor to output fullsceen? Thanks |
this may seem trivial....but right now my dreamcolor is used as my fullsceen monitor, unfortunately when connected to displayport it is assigned monitor number 3 (i need displayport for 10 bit output from other apps)
cineform sequences always output fullscreen to monitor 2 (as far as i can tell) and there is no way of reassigning monitor numbers in windows.... with a default ppro sequence it is no problem as it allows you to select the output monitor |
