neo/hdmi capture
Good Morning,
I am setting up a rig with intensity Pro Shuttle and was wondering if Neoscene can recognise the camera and capture from the sony fx 1000? right now it is not finding the camera. dale |
Re: neo/hdmi capture
That would probably be an issue with Blackmagic drivers or CineForm support for the Shuttle (I'm not sure if the Shuttle is supported by NeoScene / HDLink). Since you're capturing either through HDMI or Composite, it doesn't matter what camera you use because the signal should be the same for any input device.
| All times are GMT -6. The time now is 11:17 PM. |
