Cineform Neo3d no audio
hello in cineform neo3d convert one video avchd mts filewith HDLink to mov put no audio how to fix this? view the codec --- Codec ID : sowt
italian_pizza.mov Format : MPEG-4 Format profile : QuickTime Codec ID : qt File size : 215 MiB Duration : 22s 360ms Overall bit rate : 80.8 Mbps Encoded date : UTC 2011-06-29 17:13:50 Tagged date : UTC 2011-06-29 17:14:29 Writing library : Apple QuickTime Video ID : 1 Format : CineForm Codec ID : CFHD Codec ID/Info : CineForm High-Definition (HD) wavelet codec Duration : 22s 360ms Bit rate mode : Variable Bit rate : 79.2 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 fps Bits/(Pixel*Frame) : 1.529 Stream size : 211 MiB (98%) Language : English Encoded date : UTC 2011-06-29 17:13:50 Tagged date : UTC 2011-06-29 17:14:29 Audio ID : 2 Format : PCM Format settings, Endianness : Little Format settings, Sign : Signed Codec ID : sowt Duration : 22s 360ms Bit rate mode : Constant Bit rate : 1 536 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Bit depth : 16 bits Stream size : 4.09 MiB (2%) Language : English Encoded date : UTC 2011-06-29 17:13:50 Tagged date : UTC 2011-06-29 17:14:29 Menu ID : 3 Language : English Encoded date : UTC 2011-06-29 17:13:50 Tagged date : UTC 2011-06-29 17:14:29 |
Re: Cineform Neo3d no audio
neo3d for pc or mac?
what kind of avchd? avchd often have ac3 audio, and you need to have a decoder on your system to read it. you can find a link of free ac3 decoder in a page where you download cineform. |
neo3d for pc
video avchd mts from sony nx5 hd 1920x1080 17 mbs Audio ID : 2 Format : PCM Format settings, Endianness : Little Format settings, Sign : Signed Codec ID : sowt Duration : 22s 360ms Bit rate mode : Constant Bit rate : 1 536 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Bit depth : 16 bits Stream size : 4.09 MiB (2%) i have instal ac3 filter decoding put not work the audio in convert file |
the sony nx5 hd records to linear PCM so no ac3 issues...
and it is 16 bit (24bit is incompatible with CF) so thats a hard one to diagnose....it also records Dolby digital as well as PCM in HD mode...and that would bring some of the AC3 issues into play...but your codec report says linear PCM I did a quick google search and it looks like some people have had problems with signed PCM in quicktime containers....but not sure how accurate that is |
