Cineform sequence won't show up
I'm changing laptops right now and I'm having a real hard time understanding why GoPro Cineform Studio won't work on Premiere CS5.5.2 on my new laptop. I've recently installed it on my old laptop on the same version of Premiere and I can see all the cineform sequences. On my new laptop the installation goes perfectly but when I try to create a cineform sequence on Premiere the sequences are not there.
I've found a Cineform folder on my old laptop on C:\Program Files\Adobe\Adobe Premiere Pro CS5.5\Settings. But on the new one this folder is not there. I've tried copying the folder manually from the old laptop but I was sure it wouldn't work and it didn't. I´ve bought this laptop specifically to edit. It HAS to work. Any thoughts? |
Re: Cineform sequence won't show up
Never mind I should have read your post more closely.
You've probably tried this, but maybe installing Cineform as Admin?
Otherwise, Cineform installs different bits in three different places. Jake provided this excellent guide for Prem Pro CC, but I think it's similar in CS5 (certainly I had to do it manually in CS6 on one of my machines): http://support.cineform.com/entries/...be-CC-Windows- |
I've tried copying each folder/file individually like the tutorial on the link says and it's looking good. I had to leave due to a prior apointment but I had time to open a new sequence with the cineform presets. I'll do some more tests latter but it looks promissing.
