-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   Cineform and Vegas 6 (https://www.dvinfo.net/forum/cineform-software-showcase/70523-cineform-vegas-6-a.html)
Ryan Maes June 29th, 2006 12:23 PM
Does anyone know of a good tutorial for using cineform with vegas?
I'm trying to change my project properties for video in vegas to 1080/24 but it's not listed as an option. What settings should I use?
I've already successfully installed the trial for cineform connect hd. Am I doing something wrong? Do I have to make vegas somehow "rocognize" that I'm using cineform or are the two totally independent?
David Newman June 29th, 2006 12:37 PM
Vegas and CineForm are complete independent, yet work very well together. Vegas doesn't have a 1080p24 preset but it is simple to make one.
* Select File -> New.
* Select a Template that is close e.g. "HDV 1080-50i (1440x1080, 25.000 fps)"
* Change the Frame Rate to "23.976" (the real 24.)
* Change the Field Order to "None"
* Rename the template to - "HD 1080-24p (1440x1080, 23.976 fps)" or similar
* Click on the disk icon to save.
Now you can open any new project as 1080p24.
Ryan Maes June 29th, 2006 12:56 PM
Awesome!
Two more questions:
1. You said -- Select a Template that is close e.g. "HDV 1080-50i (1440x1080, 25.000 fps)"
Since I am using a NTSC camera, would I want to choose 1080-60i (1440x1080, 29.970fps) . . . or woud I want to stick with what you said because it's closer to the 24fps framerate?
2. Is there a similiar method for setting up vegas for 720/24pn material?
Thanks again
David Newman June 29th, 2006 01:12 PM
Try it, you will work it out. Sorry I'm in a rush at the moment.
Ryan Maes June 29th, 2006 01:20 PM
No problem. I can wait till you have time.
David Newman June 29th, 2006 04:36 PM
No seriously it is so easy. Try it youself first, then ask me if you have an issues.
Ryan Maes June 29th, 2006 05:27 PM
Okay. Tried it. I think I figured out how to import and work with 720p material. Great.
However, my other question is not something I can test, I don't think. (Well, I can test it, and both methods seem to work, but what method is preferred -- HDV 1080-50i (1440x1080, 25.000 fps) or 1080-60i (1440x1080, 29.970fps)?
See original question below...
Since I am using a NTSC camera, would I want to choose 1080-60i (1440x1080, 29.970fps) . . . or woud I want to stick with what you said because 25fps is closer to the 24fps framerate?
David Newman June 29th, 2006 06:38 PM
As you have created a new template, is has no baring to what you started with. I just made it simple, fewer parameters to change -- but you could have done the same with 4x3 NTSC DV template.
