Problems with my Cineform
Hey,
I jsut ordered and downloaded and installed cineform 4.23 After installation and activation, HDlink works, but I don't get cineform projects offered in premiere (2.0). I went through the activation process, but under Start>Programs>AspectHD>activate, the serial number slot is still blank. I tried to enter my serial number to un-grey the Enter Key button, but it wont let me type in the spot (or any other spot for that matter) Ideas? |
You need to register you product to be any activation key
http://www.cineform.com/register.html " but I don't get cineform projects offered in premiere (2.0). " Projects? To do mean presets? These should be visible when you select "New Project" in a folder called "CineForm". If not, sometimes Premiere installs are missing the registry key we use to install the presents (everything else works.) If this is the case you maybe need to uninstall both a Premiere and Aspect HD, reboot, then reinstall both. |
