nanoFlash Firmware Notes at DVinfo.net
Convergent Design Odyssey
Old July 30th, 2009, 05:28 AM   #1
Dear Friends,
Here are a couple of notes on the nanoFlash.
With our initial nanoFlash firmware does not support "Hot Swapping".
Thus, while recording or playing back, do not add or remove a CompactFlash card.
We will be adding Hot Swapping as soon as possible to both the nanoFlash and the Flash XDR.
Currently whenever a card is inserted, we go through a procedure to identify and checkout the card. We do this to ensure that when we record to the card, it will work properly.
The problem is that during recording we do not have time to properly checkout the card and also record.
There is a known issue with our Audio Level Meters during playback.
The audio level meters will display proper levels, then for a short time show 0dB, then resuming showing the proper audio level. This pattern repeats.
Dan Keaton
Augusta Georgia
Old October 13th, 2009, 08:20 AM   #2
Could you provide ...
The upgrade procedure listed as a sticky might help as a fast reference. I'm still looking for the info on the last update.
Dean Harrington is offline   Reply With Quote
Old October 13th, 2009, 03:44 PM   #3
Hello Dan,
The "Hot Swapping" feature is a must for long form work and idea when this will be implemented.
Lance Librandi is offline   Reply With Quote
Old October 19th, 2009, 05:00 PM   #4
Can you Hot Swap the cards while not recording or playing back? We have been shutting down the units anytime we eject or insert a card. Can we leave the units powered on?
Ted O'Brien is offline   Reply With Quote
Old October 19th, 2009, 05:23 PM   #5
Dear Ted,
Yes, please feel free to insert any card, eject any card, and replace it with another, as desired, as long as the nanoFlash is not recording or playing back.
There is no harm to the card or the nanoFlash in doing so.
In the future, we will also allow hot swapping while recording and playing back.
Dan Keaton
Augusta Georgia
Old October 19th, 2009, 05:25 PM   #6
Hi Ted,
I have been swapping my cards after about 5 seconds after getting green lights on CF1& CF2 which is also the recommended time for changing menu items after recording. I have not suffered any problems, the manual states when not change cards so changing cards any other time must be ok?
Old May 27th, 2010, 06:10 PM   #7
nanoFlash firmware beta release 1.5.249
Hello Dan et all at CD,
Thank you for the new Beta Firmware with all the fixes and add ons!
Thank you
Luben
Luben Izov is offline   Reply With Quote
Old May 27th, 2010, 07:08 PM   #8
Dear Luben,
As promised, this firmware, has the "File locking" removed.
We would have liked to implement the "File Locking" function as a menu option.
However, at the time we decided to implement this as a menu option, we were already deeply involved in testing this firmware release. We did not want to make this firmware change, then have to restart our testing again from scratch.
"File Locking" as a menu option is scheduled for our next firmware release.
Dan Keaton
Augusta Georgia
Old May 27th, 2010, 07:30 PM   #9
Thanks. Just downloaded and updated without incident. Will report as I have the opportunity to shoot with it.
Ned
Ned Soltz is offline   Reply With Quote
Old May 27th, 2010, 07:37 PM   #10
Dan or Mike,
What's the future status of the 2 Channel analogue in with SDI audio feature.
David
David Cherniack is offline   Reply With Quote
Old May 27th, 2010, 07:52 PM   #11
Dear David,
The +2 channel audio feature is still on our roadmap.
We delayed this to work on issues reported by our users.
Dan Keaton
Augusta Georgia
Dan Keaton is offline   Reply
