Nano or XDR with Canon XH-A1/s (Not G1) at DVinfo.net
Convergent Design Odyssey
Old September 16th, 2009, 07:41 AM   #1
Can anyone confirm if the Canon XH-a1 can benefit from these recorders besides having a tapeless workflow?
Nolan Craigwell is offline   Reply With Quote
Old September 16th, 2009, 08:18 AM   #2
Both the Nano and the XDR were designed for camcorders with an HD-SDI output port. The Nano also can accept output from a cam with HDMI output. As the subject camcorder has neither of these outputs, I don't see where you would feed these flash recorders.
I wonder though if there were a converter for your component output to HD-SDI if you would then gain the color space of 4:2:2 and higher data rate recording?
If you could upgrade your A1 to an XHG1 then you would have the same familiar camera but with the needed HD-SDI that bypasses the internal HDV compression.
John Richard is offline   Reply
