NanoFlash Slow Motion Settings For Sony EX3 at DVinfo.net
Convergent Design Odyssey
Old May 24th, 2013, 07:52 AM   #1
I can set my EX3 for slow motion, per the manual, at 720/50p (PAL). How do I set my nanoFlash to record this?
It's currently set to 1080/25p. Presumably I'll need to change this.
Ron
Ronald Jackson is offline   Reply With Quote
Old May 27th, 2013, 10:31 AM   #2
Re: NanoFlash Slow Motion Settings For Sony EX3
Dear Ron,
The nanoFlash automatically adjusts to the incoming video stream.
Thus, if you set you camera to 720p50, 720p59.94 or 720p60, then the nanoFlash will automatically record that format, and display this value on the Frame Rate Display (the highlighted line near the bottom of the screen).
Respectfully
Dan Keaton
Augusta Georgia
Old May 31st, 2013, 01:50 AM   #3
I tried that Dan and as you said the nanoFlash recorded at 720p50, thus no slow motion. Presumably I need to do something with the nanoFlash settings as well.
Ron
Old May 31st, 2013, 09:36 PM   #4
Hi Ronald,
I have used my nanoFlash for over cranking and made the following notes, they may be of interest. I can't actually run a check of my notes at the moment because my EX3 is currently on tine lapse duties.
nF over and under crank starting from pre-record: -
• Set camera to 720p50
• Turn off prebuffer (system > prebuffer).
• Change long GOP to I-frame (video > codec).
• Turn 720p 60/50 etc off (video > 720 p etc)
• Crank: - turn on (Black tick in white rectangle)
Set record rate to 25 for max overcrank press ok (choices 24, 25, 30, 50, 60.
Set crank rate (1 max speed up or 60 max slow down) press ok
Old June 7th, 2013, 06:15 AM   #5
Thanks for that Alistair and I got it to work. Been sorting out how to combine slo-mo 750p footage with normal 1080p but I think I've got it fixed.
Ron
Old June 7th, 2013, 06:32 AM   #6
"720p" of course
