Metadata Support
We are now discussing the addition of user definable metatdata to the Flash XDR and nanoFlash products. This metadata could include some of the following information: Take Number, Good/Reject, Client, Date, Camera Type, Location, DP, Shutter Speed, Video Format, Bit-Rate, etc. Some of the data would be entered by the user and some would be automatically extracted from the recorder (such as the video format and bit-rate).
We are still debating the best method to enter this data. One possible approach is to create the files on a PC/MAC and upload to the recorder via a CF card. You could define a key word, such as Location and then enter several possible choices (New York, London, Paris). Then in the field, you could select the appropriate choice from a pull-down menu. After a shoot, all the QT or MXF files (with embedded metadata) could be downloaded to a common file folder on a PC/MAC. Then using our (yet to be developed) metadata extractor, you could create one XML file which has the extracted metadata from all the QT/MXF files. The XML file could then be loaded into Excel for analysis. The real benefit of metadata can then be realized with yet another software tool we are considering, which allows the user to find all files with a specific attribute, (such as location = London) and copy these files to a new folder. Anyway, I welcome any thoughts or recommendations, such as whether anyone would actually make use of metadata? Thanks- |
Have you looked at Adobe's XMP public metadata SDK?
Adobe XMP: Adding intelligence to media There's a push for interoperability among vendors. |
It's an EXCELLENT time saving idea! Huge improvement over having to keep a written log and/or searching thru the current file naming scheme.
Metadata Support Via USB to RS485
Thanks for the feedback and recommendations. We'll take a look at the initiatives from Adobe and Avid. Naturally, we would like to be as compatible as possible.
On the hardware side, we are considering a simple USB to RS485 converter which will plug into your laptop/desktop or sub-notebook (Dell has one for $249). This converter would have USB on one side and a telephone jack on the other side. We would then create a simple connector which plugs into the 9-pin port on the XDR (or the 6-pin Hirose on the nano) and has two standard telephone jacks. You can then use standard telephone cable to connect to the USB converter and to daisy chain to other XDR/nano boxes. Using this simple connection, we can then send metadata and/or video assist commands to one one more XDR/nanos from this simple laptop/notebook. The metadata in the all the recorders can then be simultaneously updated. Or, we can send one command to all the XDR/nanos in the chain to simultaneously play back a given clip. Side-note: RS485 is a simple 2-wire half-duplex communication protocol capable of bit rates up to 10Mbps. In our implementation we would likely limit the speed to 115Kbps, which would allow cable runs in excess of 1000 feet (300 meters). |
Sounds like a very cool approach, but I am very uneasy about multiple wireless devices on a production set, especially when you have 5 or more nano/XDR units to control. I know the wired approach will work and give solid dependable results (once it's fully debugged). It's also much easier to design and much much faster to market. Best- |
Hi Mark-
I am in total agreement that wireless would be ideal, but it's simple outside the time frame to get this product completed and shipped. Yes, it is something we can consider for the future, but first we have to complete the basic metadata support code and provide a method for users to enter the data and a program to extract the metadata from the QT and MXF files. We also have plans for a program to find all files based on a certain keyword parameter, such as Client = HBO. All this code takes time to develop and debug. Cheers- |
Thanks for the recommendations, but we need to get the nanoFlash shipping ASAP. The nanoFlash does not fulfill everyone's wish list, but we're confident that many videographers/cinematographers/broadcasters will find the nano to be a very useful tool. It is still the smallest professional HD/SD recorder available and the quality of the 100 Mbps 4:2:2 footage continues to amaze most everyone. |
Best of luck on your development! Cheers- |
