-   Convergent Design Odyssey (https://www.dvinfo.net/forum/convergent-design-odyssey/)
-   -   Adavantages of 10-bit capture (https://www.dvinfo.net/forum/convergent-design-odyssey/207401-adavantages-10-bit-capture.html)
Bill Ravens April 17th, 2009 07:15 AM
Hi Dan....
So as to not hijack your other post here:
http://www.dvinfo.net/conf/convergen...-progress.html
I've started this new thread with comments on 10-bit acquisition, and other topics. After starting this on the referenced thread, above, I decided this is more appropriate to place in a new thread.
Anyway, I've been beta testing the FirstLight application from Cineform. This app allows metadata pre-processing of color correction parameters on a cineform DI. It occurs to me, in my thinking about 10-bit acquisition, that this would be very advantageous when metadata preprocessing is being used for CC. The Cineform DI is 10-bit native, so conversion from a capture format that is 10-bit is probably quite enhanced.
On a seperate topic, Cineform contacted me about my Trouble Report that the XDCAM HD codec doesn't work in NEO HD. They told me that they know what the problem is, but, that they don't have the time to fix it ;o( I just downloaded the Neo HD v4 public beta and it's NOT fixed in v4 either.
Not sure why Cineform is being so unresponsive to this. Are they po'ed at CD? Surely, the XDCAM HD codec has enough users to warrant attention.
At the present time, Avid will import the XDCAM HD codec, as you know, however, it needs to be transcoded within Avid(or in Metafuze) before it can be exported as a QT reference file. The Cineform DI is a very nice way to work around this problem, as well as the best way to change framerate on the FlashXDR captures(at least, until C-D implements pulldown on 720p60). It's very annoying that they won't give this problem any attention.
David Taylor April 18th, 2009 12:09 PM
Bill, CineForm is in no way miffed with Convergent. We're just extremely busy right now with new releases and new product offerings and can't do everything at once. We originally tested CD files last summer for conversion with HD Link and everything worked great. They no longer work, so something changed somewhere - we haven't had a chance to look into it. I did send Mike an email or two asking for some new files to test, but I don't remember if we ever received these. As David Newman indicated previously we will look into this later. We just need to get through NAB and our new product launches.
Bill Ravens April 18th, 2009 12:19 PM
good to hear, David. Thanx for your input. hope you can understand my impatience. CFHD is a MAJOR part of my routine workflow with Avid. without CFHD, I'm struggling with less attractive workarounds when i capture to FlashXDR.
