Mark Job |
September 11th, 2009 08:10 PM |
Flash XDR & Avid Media Composer 4.0
Hi Friends:
On September 30th, Avid will officially release Media Composer 4.0. This is a *significant* upgrade to this program. I think Avid has finally woken up to the fact that there is such a thing as Final Cut Pro ;-) This version of MC is *universally media independent.* In other words, it no longer matters if you have an SD or HD project. It no longer matters if you have twelve different clips with all different frame rates and resolutions (Including PAL, ATSC, and NTSC) - just drop them on the timeline and they will play instantly with no rendering. No transcoding for digital cut or DVD output. There is no recompressing of the video data. Whatever you set the project to be on NTSC SD or Pal or HD ATSC or whatever ! It doesn't matter anymore ! Since Avid MC 3.x already worked with Flash XDR files, I'm assuming it will again with version 4.x I will have 4.X soon and will run a test with my XDR to confirm. I will also have FCS 7.0 sooner and test this out as well. Has anyone with an XDR had a chance to test the files with FCS 7.0 yet ?
