My Nanoflash/EX1R mounting
3 Attachment(s)
The EX1R has a nice 1/4"-20 mounting towards the rear of the handle that the EX1 doesn't have. I decided to use it to mount my Nanoflash.
The pictures below illustrate the mount assembly. I locally fabricated the mount itself from strip aluminum. I then mounted a Dolgin EX-V battery adapter on the bracket to provide power. This provides a self-contained unit with power when removed from the camera for playback. I also have an EX1 battery with a power tap connector if I want to power both the camera and Nanoflash simultaneously. Pictures below. The first is bracket only. The second with the battery adapter. The third is the complete assembly. Carroll Lam |
Re: My Nanoflash/EX1R mounting
Carroll,
Looks great! I am like 2 clicks away from ordering a nanoflash/ex1r combo. What can be said for the differences between nano and non-nano (SxS) footage and in what situations can you see the largest differences?? Anyone can feel free to chime in here! (-: Rich. |
How did you attach the Dolgin EX-V to the bracket? Just pop in some short pan heads and hope you don't hit a circuit board?
Carroll Lam |
Hi Carroll..
How did you power your nano flash up... I see a cable coming from the unit disappearing out of view... I am thinking of purchasing one for my EX1R Thanks |
He used the Dolgin unit which holds an EX battery.
I used a Dolgin EX battery adapter (EX-V NF adapter [EX-V NF] - $68.00 : Dolgin Engineering, Camera Power Solutions) mounted on the bracket. It has a Hirose connector compatible with the nanoFlash.
Carroll |
