EX3 SDI out to nanoflash ...
I need to record from a clip on the SXS card via SDI to the NanoFlash ... the nanoflash reads the clip settings, I've set the nanoflash to record on record button ... press play on the ex3 and hear the file as the signal seems to be present but the nanoflash does not record the clip? Is this not possible. I really need to do this as it's the only way to get the clip saved. Any advice?
Re: EX3 SDI out to nanoflash ...
Pause your clip, cue to the beginning of it by pressing "previous", press record on your Nanoflash then play on your EX3.
If you are switching picture formats between clips, (this is common when you have multiple frame rates or you go from 1080 to 720 or vice versa) it confuses the Nanoflash's picture format recognizer. |
Thank you Sir ... that will allow me to get to sleep tonight ... got about 2 more hours of work to do and then send out ... God Bless!
