Motion JPEG 2000 in the Odyssey 7Q+?
One thing the portable recorder market hasn't really touched on is Motion JPEG 2000. More commonly seen as an archival format, it would make sense as an acquisition codec, but nobody has really stepped up to implement it as it might be resource intensive.
Does the 7Q+ have the power for in the very least 1080p60 Motion JPEG 2000? JPEG 2000 is supported in the MXF format, but can also be recorded as a data stream as .mj2 files in a container similar to Quicktime and .MP4, but not identical. Having Motion JPEG 2000 in the Odyssey might change perceptions of Wavelet codecs in portable recorders. I'm only here to give the consideration of implementing it into the Odyssey. |
Re: Motion JPEG 2000 in the Odyssey 7Q+?
Dear Jack,
At this time, we have not investigated adding Motion JPEG 2000 to our Odyssey. Respectfully, |
All I'm saying is all recorder companies are heading down a dangerous path that if one or both of the companies should falter, the format goes down with them. We need an openly implementable wavelet codec before Apple shuts it's doors to professionals and Avid closes shop.
At this point, something from the JPEG-LA instead of the MPEG-LA seems more reasonable. |
Open standards prevent that thing from happening. No one has been willing to give them a chance though, and since recorders have moved off of MPEG-LA standards, it's really concerning we have codecs not made by an experts group being so widespread. Case in point: Who still uses Sorenson Video as a codec? Nobody. |
And the fact that you will poo-poo SMPTE VC-3 and point to MPEG-LA as an example of "open standards" is totally ludicrous. You should really research this topic more. |
MPEG-LA had better longevity. MPEG-2 is still in use today as a legacy system. I'm not making the point that the MPEG-LA are open. In fact, they're the complete opposite of open. The fact you would go out of your way to interpret my words as DNxHD is inferior to a closed standard is frankly insulting.
My point is longevity, and thus ProRes is unproven and is now at risk due to already weakening support for it from it's manufacturer Apple. Once the recorder companies moved off of standards made by experts groups instead opting for ProRes, I became extremely skeptical cause of the nightmare Apple has caused, and is continuing to cause for PC NLEs. JPEG 2000 has been around since... well, the early 2000s. It's an open standard and it hasn't gone anywhere. In fact, it's been standardized in archival and DCP delivery. Quicktime as a CONTAINER is accepted at the Library of Congress. ProRes is only partially documented by them and this causes it's draft status to remain preliminary. Apple won't give up those specifications. Someone seriously just needs to adopt a royalty-free, open implementation wavelet codec that has wide NLE support. Dirac tried to be that, but nobody gave a damn. (Even though it's standardized as SMPTE VC-2) |
Wow.
Dude. I'm NOT trying to divert their attention from DNxHD. I'm making a point the solid state recording industry needs to hear. Anyone from the engineering team, double down on efforts with DNxHD, but make your next goal another openly implementable and royalty free wavelet codec. I know Premiere and Davinci have native ProRes decode now. By your terms that would ALSO divert attention from implementing DNxHD. Yes, the companies that have been licensed by Apple can spit out compliant files, but just cause a lot of companies have it doesn't mean it's 100% open. They likely all had to sign NDAs to use the codec. |
Besides you asked me: Quote:
I agree with OP1a. This is one point we can agree on cause Quicktime nonsense is rampant in the SSD recorder industry and it needs to be fixed.
You can still suggest something for consideration. This isn't communist China where you're gagged from stating stuff for consideration. A Redditor in the industry made a comment that made me suggest this to the CD crew: Quote:
There are strong examples where big companies have refused to open source something that has become widely used. Take for example exFAT. Owned by Microsoft, the SD card association adopted it in their SDXC standard which means all kinds of headaches for people on Linux cause the source is not openly available and the whole thing is protected by multiple patents. FAT32 isn't this way. Also, Linux can't be like "Well, just adopt it you lazy bastards." due to the nature of they will be sued out the ass if they included proprietary elements with base packages. |
