Keylight glitch
Has anyone else noticed a glitch when using the Keylight plug-in for AE?
During normal work, I never see this, but when I go to render out a comp (apparently to any format) every so often the renderer will skip the bottom half of a frame. I can actually see the frames blanking out in the pre-viewer as the renderer runs. Sometimes it is only on a pre-composed layer (and other layers in the same rendered frame are okay), sometimes it's all layers a frame. What I've discovered is that I must deactivate Keylight (the little "f" button in the effects pane) and reactivate it to get the glitch to clear up. Anyone else seen this, and/or fixed it? |
I haven't run across this, but I've only used KL once or twice. What version are you using?
Whichever version shipped with CS2.
Nobody's seen this, eh? I'll look at a re-install... |
