-   Digital Compositing and Effects (https://www.dvinfo.net/forum/digital-compositing-effects/)
-   -   FX Filters that change with the sound of the clip (https://www.dvinfo.net/forum/digital-compositing-effects/107184-fx-filters-change-sound-clip.html)
Chris Knight November 3rd, 2007 05:27 PM
So let's say I have a clip with a filter on it (contrast, threshold, whatever) I want an attribute of the filter to change according to the trend of the sound that accompanies the clip.
So if I have a clip of a man talking, If he isn't speaking, there is no effect, if he is whispering, there is a little effect, if he's yelling, the effect is very pronounced.
How can I make this happen? What software do I need? I have FCP and Motion. But I can get access to other things through my school if need be.
Carl Middleton November 3rd, 2007 05:32 PM
You may want to check out After Effects.
With the 'Turn Amplitude Into Keyframes' (I think it's called) setting, you get a number, I believe 0-1 or 0-100, of percentage of max volume. You can then tell any setting on any effect to use this value. For example, the sound clip of a flickering light (zzzt-zzzzt) could change the opacity of the video layer, giving the appearance of the light flickering, set by the noise.
C
Daniel Ross November 3rd, 2007 06:05 PM
Good advice, or, really, you could just look at the waveform and do the same thing by hand in any application. Might be a bit slow, but shouldn't be too hard.
Jon Jaschob November 4th, 2007 02:30 PM
Another good resource for AE.
http://www.videocopilot.net/tutorials.html
Although I would do it by hand if the clip wasn't too long, like over 10 minutes.
