sound problem in AE
Hi,
i put sound into timeline and tried to preview it with 0 pad and it worked. But after rendering it was without sound. Could anybody advice me how to render it with sound? Thanks in advance |
Hi Bohumil
I'm not sure if this is the solution to you problem... When you add your project to the 'Render Queue"... next to the 'Output Module' tag it says 'Lossless' highlighted... click on that and a window opens that allows you to chose your output format.... At the bottom of this is the audio... if it is greyed out you need to click on the little square to the right of 'Audio Output' and it gives you the audio options... If you don't do this when you render it renders without audio... Hope this solves your problem cheers Gareth |
